I got Queen - A Night At The Opera dvd-a recently, and I want to rip the PCM tracks so I can listen to on my pc without dvd. So far, I:
1.) Demuxed pcm using Stream Processing
2.) Renamed .wav to .pcm
3.) Opened in Cool Edit Pro
This is where I hit a snag. As you know, PCM is raw audio data, no headers means lots of guessing. Smartripper told me it was 96kHz, and 24-bit. So I opened with all the 32-bit (float) settings. When I opened as a 32-bit IEEE Float (0.24), it was solid noise, but in backgroud faintly and above normal speed, it was playing softly. ALl other settings gave just noise except one. The 24-bit packed Motorola PCM gave me complete noise on the left-channel, and right-channel perfect sound (the way it's suppose to be). I tried to off-set the data reading to see if that fixed other channel, but it turned both channels to noise. Did I hit the end of the road, or does someone know something I don't?
Shouldn't you open it with normal 96kHz/24bit pcm settings because that is what your pcm file is? Also is this pcm track the real dvd-audio portion or is it from the dvd-video. Because many times, I believe because I know the specifications allow for it, dvd-a is encoded with a lossless compression called MLP. So, if it is MLP encoded, you will need an MLP decoder which will probably cost a good sum of money.
No, its from DVD-Video part, I skipped the MLP and DTS and went straight for PCM. Also, there are no plain 24-bit modes. There are the 32bit IEEE Float modes, then an Intel packed and Motorola packed 24bit mode. Intel didn't give me nothing, motorola gave me one channel, as I said.
Just came across something. I tried Intel packed 24-bit with an offset of +1, and it gave me left channel perfect and right channel noise, and I pieced 2 different channels together. I then found out that they are same channel, not separate ones. Again, any help at all would be nice.
Why did you rename the .wav to .pcm? Smartripper might add the correct wav headers.
When it opened as a wav, it opened as a 48kHz and 16 bit, which gave me nothing but noise also. I'll see if I can change any settings to get it to open as a wav tho.
EDIT: still nothing -
Anyone know how to change values in a wav header? The header is tricking program into thinkin it is a 48kHz 16 bit file, is there anyway I can correct it to 96kHz 24 bit. Or perhaps does anyone know how to strip the header off, it may be messing up the sync when I open as a .pcm
if you dont have a 24 bit sound card you cannot play it back without reencoding to 16bit
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Help in DVD Ripping?
By itsjamesd in forum MacReplies: 6Last Post: 9th Nov 2010, 13:55 -
Ripping Saw 6 (Saw VI) dvd, HELP!!!
By diluvian8 in forum DVD RippingReplies: 5Last Post: 27th Jan 2010, 22:45 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 13:11
