Results 1 to 13 of 13
  1. Can it really be that i have to accept that my newly purchased bulkpaq doesnīt work?? I have now burned xbox,video and data on my bulkpaq gen 3 and out of 20 burned only 1 has worked.
    Does anybody else have this problem??
    If it aint broke, donīt fix it.
    HAPPY 100th HARLEY-DAVIDSON
    Keep up the assembly line Willie G.
    South Wales
    If you're refering to the bulkpaq purple top gen 3's, then yes i have a problem with them aswell, they will atart to burn the initialising stage with Prassi, then fail, DVDR no good, i have 15 to return to place i bought them from, bought 60, 45 seemed to b ok, 15 no good
    Max
  3. I have had the same problem with Prassi.. If you set the recording speed to minimum,then it will write them ok,but i canīt read them when it is done..I have now done about 10 and only 1 has worked,and i have used both prassi and nero and i have tried data,xbox and video as i said only 1 has worked..
    South Wales
    I did try that, reducing recording speed, still threw them out, i was on a site last week, and it said that they were still having problems with the purple top bulkpaq's, i won't b buying n e more of them
    Max
  5. MAN this sucks as i just recieved my 150 pieces today.I will see if the company will take them back as it is too expensive to just have 1 out of 20 to work..
  6. Check the new Bulkpaq X4 speed Tango's they are the nuts no blow outs it looks like Bulkpaq have sorted their Sh*t out at last. All 25 burnt fine at X4 speed no blow outs and they all played back in my Datawrite dvd player no hasstles
  7. this does not help me as i still have 130 discs i canīt use for shit..
  8. Send them back to the supplier they should take them back if they are half decent if not dont but Sh+t of them in the future.
  9. I hope they will take them back..It is getting very expensive to try and figure out why this shit doesnīt work..
  10. I have used them all mate there a re a few out there no names mentioned but I know use www.nexus22.com everytime i have bought disks of this guy I have rang him first and he has been dead up front if he thinks I am going to have probs with the disk he wont sell them as he say's " it wastes both our time and makes me look like a t+at". give him a ring or email the geezer you wont be disapionted
  11. Thank you very much for the link osion,i have already sent him a question.. I have updated the firmware in my DVR-105 with one that has no region codes,allow 2x recording on all discs,do yuo think this will make the bulkpaqs work for me??
  12. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    Try using Verbatim DVD-R, they are a little more than the rest but they have great playback in everything I have tested.
  13. I know verbatim is good,so is the price they are twice as expensive as bulkpaq..even so i will only buy dvd-r with ritek dye in the future..I have just ordered 150 Datawrite Classic yellow
