For a long while I was using Video Factory to Capture, edit and render. Then Vegas. I had Adobe Premier but since I did not like the editor, I did not use.
Started noticing that when I capture with Vegas video via iee1394 from Digital 8 cam, during capture it drops a shade or two in brightness. Never really paid attention before. But everytime I press RECORD (capture) the picture dims.
SO I tried in premier and it does not do that. Have wound up now, capturing my clips with premier and then import to Vegas. What would cause this ? I know Premier is using the MS DV capture driver. Is this the root cause, does Vegas use mainconcept or something else ?
Thanks in advance.......
Results 1 to 1 of 1
Vegas Pro 9 versus Adobe Premiere CS4 ?
By Chrushev in forum EditingReplies: 1Last Post: 23rd Oct 2009, 19:23 -
Problem at Adobe Premier 6.0 : Extracting .MOV movie
By chineloninja in forum EditingReplies: 1Last Post: 8th Jul 2008, 19:03 -
Vegas Pro 8 versus Adobe Premiere CS3
By SCDVD in forum EditingReplies: 9Last Post: 26th Feb 2008, 18:57 -
Adobe Premier Pro 2nd. monitor problem
By ofalcon in forum EditingReplies: 1Last Post: 7th Nov 2007, 11:49 -
problem with my adobe premier 7.0
By pondleaping in forum EditingReplies: 4Last Post: 13th May 2007, 11:29
