    Apr 2003
    Denmark
    I try to cut some poor scenes out of an almost finished SVCD movie.
    In TMPGenc the "cut" is not exactly where I order it to be -not precisely enough, for some reason. So You have to cut "some extra", but how much??
    Then I tried VCDcutter, but cannot make it save my clips. There are 4 buttons, step 1 through 4, but it seems my buttons 3 and 4 are not active ??? The help file is next to nothing. I select "clip mark in" where I want to start, and "clip mark out" where the clip should end - and then I am suposed to get the clip down in the "clip list" by selecting "add to clip list" but as I said, that doesn`t work.
    SO: Can anyone solve one of these two software problems for me OR suggest a third and hopefully better working peace of software???
    Thanks/Preben
    Thanks -
    Ps.
    Mar 2002
    canada
    well is best to do your editing before you convert to svcd. next time, use virtual dub first to remove the bad frames,then convert your file
    Apr 2003
    Denmark
    ah yeah, I know - but kind of too late now.
    Anyone can answer my questions please?
    Thanks -
    Ps.
    Mar 2002
    canada
    if you still have the original avi,i would suggest starting over,as there is no exact mpeg2 editor,that i know of.
