  1. The Best Capture Program?
    What is the best capture program? Simple! Recommend me something
    Cheers
  2. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    It all depends on what type of capture device you are using. Most DV devices work well capturing directly to the editors (Premiere, Ulead Studio, etc.) I've found that the cheaper cards (WinTV, Studio PCTV) work well with PowerVCR.
  3. im trying to capture from VHS and the program it came with is really difficult to use.
  4. Greetings Supreme2k's Avatar
    Feb 2003
    But how are you getting the VHS into your computer? What capture device are you using? Canopus, Dazzle, Pinnacle?
  5. InterVideo WinDVD Recorder.
    You can capture straight to DVD or captured DVD compliant MPEG's.
  6. can u capture to vcd or svcd compliant mpegs - or avi
    Aug 2002
    England
    Yes you can but the results will be poor.
    You need a high bitrate when capturing mpeg.
    Then you encode to VCD/SVCD after.
    PowerVCR2
    WinDVR2
    Powerdirector Pro 2.5
    All good programs for capturing mpeg2.
    Fozzee
