This is for the older versions of Coby DVD 507 that support VCD.
This hack is done almost the exact way as the multiregion hack.
Turn on your player with no disk in it and get the Coby Blue Screen. Now Press "Setup" and then Vol(+) Vol(-) Vol(+) Vol(-). On the upper right hand corner it should display "Ver ___" (1,2,3,4,5,6 or 255 for multiregion). Now press the Up Arrow Key till you get to the number 4001. Now press the Left Arrow Key to change it to 4000. This will eliminate macrovision. Once you do it you won't need to do it again (unless you unplug it maybe).
Results 1 to 1 of 1
hack for dvd player COBY TF-DVD7377
By smedina in forum DVD & Blu-ray PlayersReplies: 8Last Post: 6th Jul 2009, 22:16 -
COby 224 Hack Problems
By cinefile in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Jul 2008, 04:30 -
Coby DVD-211 Region Hack
By pabco33 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Jun 2008, 19:52 -
Coby tf-dvd3271 Hack
By roar54 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th May 2008, 20:59 -
Region hack not working Coby TF-DVD1020
By srelov in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Mar 2008, 22:27
