I'm new to all this and found this great site! Found answers to all my questions I had but one............
I bought a digital camcorder (JVC G70U) and Pinnacle Studio 8. I'm happy with both but would like to keep the best resolution of some of the stuff I shoot. I learned at this site that the best is to make DVD disks. But......... I don't have a burner. Questions:
1) If I male VCDs, I see that the quality is a little better then a VCR tape. Can not use SVCDs. If I make the VCDs and use the lower quality compression (MPEG or MPEG2), will I be able in the future make those files revert back to their original quality? That would be uncompress back to I believe AVI that my Studio 8 captures at (720 x 576 pixels) and burn them to DVD when I can afford one?
2) What if I just make my movies and output them to tape. Studio 8 allows you to do this but does notgive you a choice of how it is being sent back (MPEG1, MPEG2, AVI, etc.). It gives you all kinds of choices for outputting to VCDs and using different compression standards. I guess by sending the movie back (output) to my camera, I am hoping to put movie on blank tape at the original excellent (720 x 576 pixels) quality for future retrieval. Is that what would happen ? The only choice I really am given for output choices to tape are VCR or Camcorder
Thanks in advance to anyone that can help this newbie out!
If you intend to burn on DVD, later on, you are better off outputting to a DV tape. DV is less compressed than mpeg-2. The quality of DV is better than mpeg. So DV is actually better than DVD in terms of quality.
Going from VCD to DVD is a possibility. But you would essentially being burning vcd quality files to a DVD. The quality would not be improved by doing so. But you could fit longer videos into a DVD.
VLC Player's "record" feature- can I change the output folder?
By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 30th Mar 2012, 00:32 -
Output of both m2v AND ac3 during single "Render As" event in Vegas?
By Smells_Like_Feet in forum EditingReplies: 3Last Post: 28th Oct 2011, 20:08 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
Does the ps3 fat output "bitstream" audio for aac?
By yoda313 in forum AudioReplies: 0Last Post: 12th Dec 2010, 17:03 -
"Any Video Converter" output format choices - can anyone explain?
By slipkid in forum Video ConversionReplies: 5Last Post: 14th Feb 2009, 18:09
