I'm getting what appear to be completely standard format SVCDz out of my tmpgenc encoder, but when I view them on anything that is not a computer (DVD player - several diff models) they all appear 'squished' top-to-bottom.
I realize that pixels are not considered 'round', especially on a telly screen. I've tried both the 1:1 VGA aspect ratio as well as 4:3 (NTSC) and 4:3 (NTSC) 525 lines. Same result on all three.
I'm not sure how else to explain this, I've tried encoding some DV clips to SVCD. Original rez of the DV files are 704x480. I'm shrinking them down to fit into the standard SVCD size of 480x480.
My math looks like this:
704 480
480 327.2727...
The file is resized using a VDUB filter that adds the letterboxing to bring the output rez back up to 480x480.
I take this newly resized file and frameserve it over to tmpgenc. My SVCD settings are fairly generic, 1-pass CBR @ 2200kbit (30 minute snippits). These settings work well with all of my family's DVD players that I've tested so far.
I've noticed this with DVD'z that I've shrunk down to fit onto an SVCD.
Even if VDUB saves the file rather than FServe'ing it, the AVI output looks fine, but when encoded to MPEG2 and viewed in a DVD player, things get squashed.
Any ideas?
thanks for your time.
-elf
It's you aspect ratio. All computer videos are 1:1 while a TV can be typically 4:3 or is you have widescreen 16:9, but never 1:1. This is why DVD's look tall/skinny on a computer if you don't use a DVD friendly player (if you use WMP with VOB plugin, it will look skinny).
Try DVD2AVI and the VFAPI plugin, then encode with TMPG with the SVCD template, and you shouldn't have this problem anymore.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Can one use DVD2AVI with DV video from a camcorder? I believe all of my caps are DV Type II, which will open in VDUB.
The VFapi plugin is something that tmpgenc can use to open odd avi files?
Squashed ffmpegx Flash Video in iWeb
By IrishP in forum ffmpegX general discussionReplies: 10Last Post: 20th Jun 2011, 09:32 -
Squashed picture/removing the fake black bar?
By Joolz2020 in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2010, 07:56 -
DV looks normal on camera screen, but is squashed to 16:1 when loaded to PC
By marbetu in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2010, 08:09 -
Converting 16:9 DV-AVI to Divx/XVid, its always horizontally squashed...
By mjvgiese in forum Video ConversionReplies: 2Last Post: 20th Jan 2010, 22:18 -
Streaming Video with vista 64bit Squashed! HELP!!!!!!!!!!!!
By dking in forum Video Streaming DownloadingReplies: 1Last Post: 21st Jul 2009, 14:17
