Is there any TV tuner software available that'll work on the Video In/Video Out port of my GF4? It only has S-video in, but I can use a converter to run a TV aerial into it.
Stemming off from the part about TV aerial converter, the one I've seen converts aerial to RCA, and I then use an RCA to svideo converter. Thing is, the aerial -> RCA converter I've seen only had the yellow plug, so how would I go about getting sound?
Plug the jack into your Line-In of your sound card ??Originally Posted by legionpc
Maybe TheFlyDS from http://www.asvzzz.com/index.htm will work. I've never tried it with your setup, but it does allow you to watch tv through a VIVO connection. Not sure about the tuner aspect.
BG -
Obviously you didn't read my post properly :POriginally Posted by skateni
I said that the converter only had the yellow plug - thus no cable to plug into line-in. The aerial cable has sound and video in the one thing, right? With the converter, there is only a video plug, so how am I supposed to access the sound that is coming through the aerial cable? -
Perhaps this picture will illustrate what I mean a bit better:
Do you see how on the cable that has a female aerial plug on one end, and an RCA connector on the other end (aerial -> RCA cable) it only has the one, yellow video part? Notice how there is no red and white cable for sound? My question is how am I supposed to get sound here? Are converters available that have all three RCA plugs on the end?[/img] -
you can't plug a cable/arial signal in your card. It is a completly different type of signal, ou need a tuner to demodulate the signal. What you can do is use a vcr with a svid/scart out, plug the arial in the vcr and plug the svid/scart in the video in.
"All that we see or seem, is but a dream within a dream" E.A.Poe
http://www.cask-of-amontillado.com/htpc.html -
Ordinarily that would have been what I'd do - but my VCR is screwed at the moment. For some reason, when watching TV through the VCR, certain channels flicker horribly every few seconds. These same channels work flawlessly if I watch them on the TV, but if I'm watching them through the VCR, I get the flicker. Hence why VCR isn't a viable option in this caseOriginally Posted by Amontillado
Turn PC Monitors Into TVs
http://www.pcworld.com/reviews/article/0,aid,104324,00.asp
or
Nokia Mediamaster 210 T terrestrial digital television receiver
http://www.pc4d.com/electronics/63/nokia_mediamaster_210_t_terrestrial_digital_televis...on_recei.shtml
Best TV Tuner Software
By Montani304 in forum Newbie / General discussionsReplies: 4Last Post: 30th Jul 2011, 12:27 -
Tv tuner software
By jjis in forum ComputerReplies: 2Last Post: 22nd May 2009, 11:34 -
TV-Tuner Software
By Beaker14 in forum Capturing and VCRReplies: 8Last Post: 5th Feb 2008, 05:49 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 03:28 -
resolved: Need source for software for capture through ATI VIVO card
By palouse in forum Capturing and VCRReplies: 5Last Post: 7th Jun 2007, 11:56
