I have taken in my home video (from sony high 8 NTSC) to PC (ATI all in wonder card) set to DVD quality (type mpeg2, video 720x480 8mbit per sec, audio 48khz 16bit stereo). The file is about 7gig. When I try to burd to dvd it will not fit. I am not understanding why my 2hr video will not fit on my 120min dvd. I don't want to loose quality but I would like to make it fit on 1 dvd. I think my two options are to reduce it or re-record at a different rate. I am looking for suddestions.
Results 1 to 11 of 11
try using DVD2One or DVDShrink or just lower the bitrate to 6000 as you will see not much diff between 6000 and 8000.
[ = Check out my band @ www.samadhirock.com = ] -
Your 2 hour video is 7 GB. A typical DVD is 4.7 GB, and can hold about 4.36 GB of data. You need to encode it at a rate which will give you a final file size of less than 4.36 GB. You may want to read under the HOW TO section to the left for the best ways to accomplish this.
Well it looks to me like you'll either have to rencode it @ 4.5 mbtps or split it up for 2 DVDs. The quality @ 4.5 mbts really isn't too bad. It all depends on the source quality. But if you wan't the best than there is no choice.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I have read and tried to get TMPGEnc to read in my mpeg2 video but I keep getting "can not open" or "unsupported". I read through the help files added codec's and made changes to the environmental settings. Nothing works. Is there a better program that I can use to make my 7 gig home movie smaller?
I also bought an All In Wonder Radeon about a year and a half ago. It was the 32 DDR version and came with ULead s/w. I thought the ULead was junk and found that ATI's own Digital VCR did a better job capturing. My experience with VHS capture has been that 'Custom setup' at 352 x 480 @ 3.00 MBit/sec mpeg-2 Medium does a decent job (one of the default Custom settings). Some of the other suggestions you have received using the new adjustable shrink s/w will probably get you even better results. My problems have been with the basic capture - dropping frames at higher resolutions and poor sync on older tapes. Not too happy with the AIW. For the record, I am using an Athlon 1.2G Thunderbird processor with 512M of DDR RAM under Windows 98SE. I use 'End It All' to shut down unecesary processes. It helps some but not enough. Maybe its time for a faster processor, new mobo or a s/w rebuild. Good luck.
Well, just my two cents. I do this type of coversion all the time for my home movies and all my friends. I have not had any problems since I upgraded my OS to XP Pro. I use Dazzle DVC II, I know some people don't like this card, but I have not had any problems after upgrading my OS. Dazzle allows you to set the bit rate very easily and does a vaery good job. The price has come down since I bought it over 1 year ago. Also I use a pIII 1.5 GHZ cpu.
I hope you find this a little helpful. -
Thanks for the info. I am running xp with a 1.8gig processor 512mb ram. I still would like to know how I can take the video that I have and convert it to a different format so that I can put it on one dvd.
pettinej
If you can't open an Mpeg-2 in TEMPenc, you can open it in Virtualdub-mod (look in the tools section of this site) then frame serve it to TEMPenc. You can then re-encode it to what ever bitrate you wan't. Use the wizard to help you set the the bitrate for the size media your using.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Is the problem the bit rate, or is it because your authoring tool only does pcm audio. Unfortunately most authoring tools don't compress the audio, so I would suspect the large bloat is more likely from the audio. It would be a shame to degrade the video quality to compensate for the uncompressed audio. You may want to find a authoring tool that will convert it to AC3 or something.
I have a 4hr mpeg 2 video and i need to fit it into a 4gb dvd-r
By missyfy in forum Authoring (DVD)Replies: 4Last Post: 3rd Feb 2011, 05:12 -
I'm massively confused: Want to fit about 2 hours worth of video on a DVD
By karlcward in forum Video ConversionReplies: 2Last Post: 21st Oct 2010, 18:51 -
Video won't fit on dvd
By chevyfever in forum Video ConversionReplies: 5Last Post: 6th Nov 2009, 08:50 -
Can I fit 5.3 GB video on a 4.7 GB DVD?
By better life in forum Authoring (DVD)Replies: 13Last Post: 16th Nov 2008, 21:42 -
Please explain this to me (lengths of video that an fit on a DVD media)
By perfection in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2008, 19:32
