  1. I just got my dvd burner 2 weeks ago and i have burned about 15 dvdr's fine and today i tried to burn a dvdr that i downloaded. And the computer reset on me while it was burning. I have tried to burn it 3 more times and the computer keeps reseting on me while it is burning.
    Any help is much appreciated it is making me really
  2. I doubt you will get many replies to this, as this forum does not advocate the use of Warez.
    However, as they say, Google is your friend... as is Alltheweb, Alta Vista...
  3. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    and you were burning........ a data only DVD? from a downloaded image? on a......DVD burner of some kind? using.......some DVD-R's of some description? bit more info needed.
