theres gotta be an easier way to put a whole movie ..no mater the length or quality on a vcd besides this article...https://www.videohelp.com/forum/userguides/84759.php...i have had one or two success with this article..is this way able to fit any size movie on say a 700mb 80 min cd-r...i have some 90 min as well..thats all i wanna do...ill PAY some one if they can show me the way.....
Try DVDx. Its an all-in-one program. Dont have to rip the movie from the DVD.
I used it when i was learning. However, I now prefer TMPGEnc.
http://www.digital-digest.com/dvd/downloads/dvdx.html
wway -
No, there isn't. VCD is a Fixed format. That means fixed bitrate + fixed CDR size = fixed maximum length of movie.
This isn't rocket science, stop trying to do the impossible. You want 2 hours of movie on 1 disk, you have to do it in DVDR or DivX/XviD.
You can try xVCD, but you will have to see if your player will support it. Personally, I wouldn't bother, since the quality will be so bad that it's not worth the effort. VCD is mediocre at best compared to CVD/SVCD/DVD.
You can also try xSVCD. I have several 2 hour xSVCD single disk movies. They look like VCD's, but then the resolution isn't 480x480. A 320x240 VBR MPEG2 stream is possible, just not as good as full SVCD. It also won't play on most players, but it was a fun experiment.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
the qucikest way would be to use easyvcd. it gives you the out option of # of blank cds you want to use plus format(vcd,svcd,xvcd), hit enter, do whatever, when its done you have a mpeg file that you just drop into nero and burn. limitations are longer movies ie: godfather, LOTR, scarface. i use it when i am pressed for time and just want a quick dvdrip.it will work with 99 min cdrs, 90min cdrs and 80 min cdrs, hope that helps....bloo
I have had great success with https://www.videohelp.com/forum/userguides/84759.php.
I do have to lower the bitrate and sometimes the audio rate to make it fit. I know this discussion will turn into a "why do you want to do it that way" and the reason is I don't have a DVD burner and I like it this way. When I get a new computer I will then go for better resolution and audio quality but am satisfied with the results at this time. -
really the only reason i wanna do this is because i dont wanna get up during playback on my standalone dvd player
Put my entire dvd collection onto my PC
By rockethead in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 16th Feb 2011, 16:02 -
Exporting a little movie file that won't consume my entire hard disk space
By Danny Pro in forum Video ConversionReplies: 5Last Post: 14th Feb 2010, 23:50 -
entire movie does not rip to hard drive?
By carlos28355 in forum DVD RippingReplies: 2Last Post: 20th Jun 2009, 05:58 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 22:40 -
Question about Burning an Entire DVD9 Movie to a Dual Layer
By |-Goku-| in forum DVD RippingReplies: 9Last Post: 30th Dec 2007, 18:41
