I was trying to capture analog video from my vcr through my ATI AIW 8500DV breakout box right in Ulead VS 6. I was dropping tons of frames.
I then tried to capture it instead using the ATI TV program and then just open up the file in Ulead. It captured with none or very few using the Tv mode. WHy would i drop frames on the exact same clip of video in one program but not on another program.
P.S. in ulead i was capturing in AVI format and in the TV mode i was capturing in mpeg2 format.
What method of compression were you using to capture the AVI ?
If none, then you are creating a very large capture file and the rate of data flow is probably too much for the hard disk to keep up with, so dropping frames is the only way to keep up.
The MPG capture is compressed so the disk can easily keep up with the flow.
Make sure that you use a fast compressor for AVI capture.
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 12:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15 -
Please help me stop dropping frames!
By justin81 in forum Capturing and VCRReplies: 28Last Post: 1st Apr 2011, 08:17 -
HDVSplit dropping frames
By Boadicea7 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2009, 09:47 -
Dropping frames while converting to .dv
By Huntr777 in forum MacReplies: 1Last Post: 10th Jun 2009, 17:19
