No mention of supporting .PDI files from IC7 in this write up but if you goto REGISTERTY and there you can associate .PDI files with DVD DECRYPTER. If you go to ISO WRITE it does show a .PDI file as a valid extension.
In the ISO WRITE mode it shows the MANUFACTURE ID for the DVD -R media that I am about to burn with. I am using 2x media with the ID of MXL RG01.
Improved detection of currently inserted media
Improved IFO/BUP file region patching code
Improved RCE Protection detection in IFO mode
Improved support for DVD+R/+RW drives
Improved error reporting
Improved drive region changing interface
Improved I/O Interface 'Debug Mode'
Improved device / disc information given in ISO modes
Improved SPTI drive detection code in NT 4.0
Improved Vob ID file splitting in IFO mode
Improved CSS cracking code
Added the ability to split by Vob ID in File mode
Added the ability to create MDS files for most image types. These can then be loaded into DAEMON Tools
Added the ability write several other types of images
Added the ability to change the volume label of supported image files
Added 'Maximum Write Speed' to the information window in ISO modes - For DVD media only
Added the ability to create Information files by right clicking on a PGC in IFO mode
Added the ability to patch the first GOP in an M2V stream so that the time is 00:00:00 instead of 00:59:59 or whatever - this allows chapter files to import directly within DVDMaestro and alike
Added support for 'Success' and 'Error' sounds
Added lots more user configurable options in the settings screen
Added 'Shutdown computer when finished' to the ISO write screen
Added the abilty to parse the ISO filesystem
Added automatic detection of which filesystem to parse (UDF or ISO)
Added automatic erasing / formatting of discs before burning
More command line options - see Readme.txt
Loads of other changes / fixes / requested features - too many to remember / mention!
also doesn't mention that it fixes the issues with Lite-On 166S DVD ROM's where on rare occasions, certain vobs won't rip. "Lightning" mentioned on Doom9 that he would have this fixed in the latest version and I noticed that on one of my rips with the 3.15, it looked as though I would get the same error, but this time it worked perfectly. Have to test some more, but it looks like this issue may be resolved for us LITE-ON 166S users. 8)
Having trouble imaging c drive with ghost 2003
By vhelp in forum ComputerReplies: 15Last Post: 28th Dec 2011, 17:01 -
Play video on windows 2003
By timmyo in forum Software PlayingReplies: 4Last Post: 20th Jul 2010, 19:48 -
Who is good with Word 2003?
By jyeh74 in forum Off topicReplies: 6Last Post: 5th Jul 2008, 16:12 -
2003 streaming service device
By arios in forum Video Streaming DownloadingReplies: 1Last Post: 14th Apr 2008, 04:32 -
Outlook 2003 question
By edong in forum ComputerReplies: 3Last Post: 28th Dec 2007, 16:06
