i'm trying to add subtitles to a movie and burn it. but when i make the frame server on virtual dub, and try to load the .vdr file in tmpgnec a window pops up and says can't open, or unsupported. can somebody help me out please.
Originally Posted by spunge
I didn't get unsupported error's but I never solved my problems.
A link to full instructions can be found here
Good luck,
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
I have the same problem, i got a error too. And i have installed the handler in Vdub.
I have named my VDR file test.vdr and get the message:
<"File D:\music\test" can not open, or unsupported>
I use the versions
TMPGEnc Version 2.510.49.157
VirtualDub 1.5.1
Maybe there is a bug or something in this versions.
But there is a other way.
You can load subtitles directly in TMPGEnc with Vobsub 2.23
Download Vobsub and install it.
Then op open TMPGEnc, close Wizzard.
Click on "Options" -> Environmental Setting ->VFAPI Plug-in
Click with right mouse click on "Directschow Multimedia file Reader" and selected Higher Priority. The Directschow Multimedia file Reader must be in the top of your window. Priority must be 1. Click on OK.
Video sourses and search you .avi movie. Make your chance in setting and load your Template. Hit than the Start
Sometimes my computer freezes when i use this method, i think i have problem with my memorycard. But you can try, maybe it works for you.
Bye Cybergirl
PS: sorry for my bad englisch
Amateur Question: My DVD9 doesn't support AC3 Audio
By Keziapurrs in forum AudioReplies: 15Last Post: 10th Jul 2011, 19:03 -
AVI won't play. VLC say's doesn't support "IV50" Format. All codecs present
By Sikander in forum Software PlayingReplies: 2Last Post: 21st Feb 2010, 07:40 -
Firefox3 doesn't support realplayer plugin
By toddfv411 in forum Video Streaming DownloadingReplies: 4Last Post: 9th Jun 2008, 18:27 -
Only TMPGenc Support .vdr
By arturjose in forum Video ConversionReplies: 1Last Post: 15th Apr 2008, 23:04 -
How can I install PPro2 on system that doesn't support SSE2?
By Sean_ve99 in forum EditingReplies: 1Last Post: 26th May 2007, 07:33
