All I want to do is capture video from a vcr tape edit it on my cpu and send it back to a vcr tape.Noone seems to know what I need to do this I have seen it done so I know it can be done.Could somone please tell me what exactly I need to do this?
You need a video capture card to capture the video (see the capture section to the left)
Then you need software to edit the video (eg. Ulead or Adobe).
To get the edited video back on a VHS tape you have three options:
1) Video card with TV out, plug it into VCD and record
2) Genlock , this overlays PC video on a video stream
3) Burn video to x(S/C)VCD or DVD then record to VHS (but then why bother with VHS ^_^)
Luck -
You might try a Dazzle capture device like the DVC100,or 200, Or The DVD Creation Station. They all hook to your pc via usb, you then hook up any video device that has composite audio, and either composite video,or S-Video to the dazzle. Capture, and edit. Then use the dazzle to output back out to vhs tape. The 3 units I listed all have the video/audio outs to do this. They start out around $169.00
SeanWe all like Sheep have gone astray... -
Try looking here firstOriginally Posted by Militia
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Militia,
You didn't say if Macrovision was an issue. Please take that into account when you make your decision.
I use the ADVC-100. It has the ability to defeat macrovision.
I'm not advocating going out and pirating videos, but I have copied in some old VHS tapes I had purchased 10 years ago that were beginning to degrade, cleaned them up, and saved them to DVD.
The ADVC-100 allows capture and playback.
Good luck!
what would the best setting for me for Handbrake ? plz answer
By FaisalKhan in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2011, 09:38 -
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 11:58 -
Question closed. Reason: answer found elsewhere
By Hurdman in forum SubtitleReplies: 0Last Post: 9th Dec 2008, 03:54 -
Hard question that nobody can answer: Why LCD > CRT?
By SignedupGuest in forum Newbie / General discussionsReplies: 31Last Post: 20th Jul 2007, 12:34 -
Need someone who has seen Transformers The Movie(animated) to answer Q?
By Denvers Dawgs in forum Off topicReplies: 10Last Post: 27th Jun 2007, 21:42
