When i open some ifo's in ifoedit in the programs chain some of them have ' Layer Break '.What is this ??????
Also is there a way to remove it.
This signifes the point where the DVD changes phsical layer. You don;t need to worry about it, our DVD-R's are single layered.
Try reading some (very!) basic information, contained in this site, and thousands of others before you ask questions. -
I know dvdrs are single layer. i was just wondering if there was a way to remove the layer break from the ifo ??
well obviously you need to re-write the .ifo files after you've ripped them. ifoedit will do this, or simply load your sound and video files in and let it write a totally new set of .vobs and .ifos
Layer break problems
By sebrame in forum Authoring (DVD)Replies: 4Last Post: 4th Aug 2010, 18:14 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Layer Break Using ImgBurn Help
By Nitro89 in forum Authoring (DVD)Replies: 8Last Post: 30th May 2010, 08:01 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 13:26 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 12:27
