I need to
Demultiplex the audio stream from an MPEG2 file
Replace the left audio track in that stream with the right audio track
Put the new audio stream back into the MPEG2 file
Can I do each of these steps with free software? Which software
does it?
BeSweet? although what switches you would need, no idea. Basically make a 1 channel mono, then re-make it back to stereo, or joint stereo, take maybe 10 minutes?
VDUB can do it with 2 passes (output 1 channel, the re-process to stereo).
This is all in WAV (pcm or mp2 audio, not ac3)To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I just tried BeSweet. Oh my. After struggling for an hour to figure
out how it works, and all those command line options, I finally got
to this point: can not find lame module. Typical unix software.
Anyway, I'm at the point right now where I can create a wav file from
the MPEG2 file. I have to be able to convert that wav file to an mp3
file, I think, in order to multiplex it into the MPEG2 video stream.
Right? Is there a simple tool that can take a mono wav file, and
convert it to a stereo mp3 file?
Alternatively, is there a way to multiplex a wav file into an mpeg2 video
stream?
Editing TiVo Recording (MPEG2/AC3) with MPEG Streamclip loses audio
By DarthEd in forum MacReplies: 15Last Post: 4th May 2012, 07:28 -
Help :Editing mpeg2
By striker9 in forum Video ConversionReplies: 4Last Post: 7th Nov 2010, 10:05 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
Editing a Mpeg2-PS file
By too2buff in forum EditingReplies: 5Last Post: 26th May 2009, 10:12 -
Editing mpeg2
By jkipp in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2007, 12:38
