    Dec 2002
    The Great Northwest
    DVD Maestro error importing .chp chapter list.
    Error Message
    "I-Frame Insertion entry rate is not consistent with current tape frame rate! I-Frame import will be canceled. (0xc102008b)"
    Scenario
    Importing .mpv and .wav to DVD Maestro, all seem well until I attempt to import a .chp file from Chapter-X-tractor. Then I receive the above error. I was just wondering if this was a know error message to anyone and a fix. More than likely something I am doing in CCE [I Frame setting]causing the 2 parts not to be compatible but darned if I know. I am fairly new to this particular procedure but I was hoping the error might ring a bell with someone, seeing this before that might speed up the learning curve for me with an easy fix. If so I would be very thankful.
    Process=frameserve .d2v with / avisynth 2.0.8.0 to / CCE 2.66.01.07 / Import .mpv +.wav to DVD Maestro 2.9 / and trouble starts with .chp file produces with Chapter-X-tractor 0.962 via original VTS_x_x.IFO
    Same happens with I try a .m2v file instead of .mpv?
    Dd
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    www.dvd9to5.com/forum/
    "For every moment of truth there's confusion in life"
    Black Sabbath/Ronnie James Dio
  2. I kept getting an import error before I realised you had to change the timecode in CCE.
    It is set as default to 01:00:00:00 and simply changing it to 00:00:00:00 sorted out all my problems.
  3. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    I get this sometimes also, usually I just set the chapter manually if I get it. SHould would be nice to not get it any longer, I'll have to look into the timecode thing.
    Dec 2002
    The Great Northwest
    IvIark fix worked
    Setting the timecode made it work thank you for the info. I wonder way they auto default to 01:00:00. Well anyway that little piece of info saved me from pulling out the rest of my hair out. I'm having a good time playing with DVD Maestro I have been using DVD Complete most recently and DVD Maestro is much more hands on in the work area and with the help of photo shop seem to make it a very powerful author system.
    TX again
    Dd
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
  5. Glad it sorted you out. Maybe one of the CCE gurus could answer why CCE defaults to this timecode, because I certainly can't understand why as I have to change it every time.
