i want to rip a dvd then run through dvd shrink to reduce to fit on to a dvd-r
my problem is that even with max compression its still above the 4.wat ever Gb
what i want to do is remove one of the extras (which is approx 1.5GB), then repace this with a 1sec blank screen ((or simlar) or screen saying deleted due to size)
can i remove the vobs from my ripped directory (i know which ones they are) and just replace with a new vob i.e. vts_05.vob
do i kneed to alter ifo file / or in doing this will it cause major problems
ADENCOOL
What you can do is either use DVD decrypter in file mode and select all the files and then just delete the ones you don't want, and then run it through ifoedt. Or you can just us ifoedit and select which files you want and don't want.
"What We Do In Life, Echoes In Eternity"
~Maximus Desimus Meridius~
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 09:30 -
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 27th Sep 2010, 00:52 -
DVD::Rip
By loster in forum ProgrammingReplies: 4Last Post: 21st Nov 2009, 14:10 -
How do i rip out a dvd?
By beecho in forum DVD RippingReplies: 4Last Post: 10th Sep 2008, 22:20 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 21:28
