i have a movie in MPEG1 file (VCD).
i tried to find any guide to add SSA subtitle
to them but i can't ...please help
which software i could use ?
i've tried to use Virtualdub with subtitler filter
and save them to AVI file no compression...
but it take lot of gig... and i have to encode back
to mpeg ?!? or i should use compression ? which one ? will
it decrease quality of poor mpeg1 ?
many confusion ...
P L E A S E H E L P
Well, if you use tmpgenc to make your vcd's, that is the way:
Open virtualdub, open your video file, and open your subtile file, in the filter menu, you know how because you say it.
Instead save your avi file, go to file menu, and click on FRAMEserver option.
A window is showed, click ok, other window is showed, put a name for vdr file and start frameserver.
then open tmpgenc and instead open you avi file, open the vdr file and make th vcd normally. -
Adding SSA subtitles to MP4 files
By ngngokkiu in forum SubtitleReplies: 19Last Post: 21st Feb 2012, 06:24 -
explorer.exe high memory usage while trying to load ass/ssa subtitles
By Nightroad in forum SubtitleReplies: 2Last Post: 17th Jan 2012, 18:36 -
Tool to convert SRT/SSA to Sony DVD Architect subtitles ?
By miguelos_net in forum SubtitleReplies: 4Last Post: 4th Dec 2011, 21:48 -
Have DVD Files, need to merge subtitles into MPEG
By geekfemme in forum Video ConversionReplies: 3Last Post: 2nd Mar 2011, 20:07 -
Removing Subtitles from VCDs and VCD-originated MPEG and WMV files....
By dadada_999 in forum SubtitleReplies: 1Last Post: 2nd Jan 2008, 20:49
