    Jan 2003
    Okay, I know there is hundreds of posts on this subject but after looking through them, I can't seem to get a straight answer. My problem is...after I am done cap-ing I play back the AVI file and it is out of sync. It's behind only about 1/2 a second. But it is very annoying! Now, is there anything I may be doing wrong for this 1/2 second problem?
  2. You say that you cannot get a straight answer, what programs are you using what settings etc....
    What is the file extension.
    If you provide these I/us will be able to help you much better
    Sep 2001
    Japan
    When I'm capturing from/to DV with VDub, I'm always having a lag of 12 frames(PAL=480ms) between Video and Audio.This can be cured with authoring thru IfoEdit (apply audio delay).
    You can check the exact delay with VDub under audio/interleaving.
    Dec 2002
    Details, need details. For fixed sync issues, just re-adjust your audio offset of you capping software.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
