I have a WinTV PVR250 and it does an OK enough Job creating MPEG2 files for DVD, it ships with a crappy editor that when cutting the file to omit commercials, makes the result lose more and more Audio sync until your stuck with Godzilla dubbing !
Is there a relatively inexpensive program that could do this function without the loss of Sync? Something pretty basic which will be used entirely for this function.
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
How do you insert an audio clip between audio clips in AVS Video Editor
By johnharlin in forum EditingReplies: 1Last Post: 19th Apr 2011, 01:17 -
Newer FFDSHOW versions screw up audio sync for me - why?
By TigerSoul in forum Software PlayingReplies: 7Last Post: 26th Mar 2010, 16:26 -
How do I uncensor a censored audio track in an audio editor?
By adidasos in forum AudioReplies: 1Last Post: 19th Jan 2009, 05:40 -
FitCD issue (audio won't sync)
By nwfn in forum Newbie / General discussionsReplies: 8Last Post: 9th Jun 2008, 13:03
