I bought Easy CD/DVD from Roxio, because I wanted to burn DVD records. But Easy will only accept m2p, while Avid Xpress DV makes m2v! Is there anyone who can give me a tip if there are work-arounds?
Results 1 to 10 of 10
m2p=mpeg 2 program stream=video and audio multiplexed
m2v=mpeg 2 video stream=only video
/Mats -
Sorry for bumping up such an old thread, and I know this sounds very ridiculous...but how would I go about renaming a file? Is it under properties? I'm so clueless...thanks!
Right-click on the file and go to Rename, or left-click on the file once then press F2.
You may need to go into Windows Explorer or My Computer, and go to Tools > Folder Options > View, and make sure that the "Hide extensions for know filetypes" tickbox is unticked and press OK if you need to change the file extension. This should then make the extension of the file visible if it wasn't already.If in doubt, Google it. -
IMO, if you don't know how to rename a file, and are nevertheless heading into the dark, misty swamp of Video Conversion Land, you've grabbed the wrong end of the stick...
/Mats -
Originally Posted by jimmalenko
Thanks for the help! I had to do the "hide extensions" part - I could never figure that out since nothing ever was listed in the first place. Anyway, thanks again!!!
Mean? Me? Na...Originally Posted by jimmalenko
/Mats
Help with m2v files
By Mikhel in forum Video ConversionReplies: 0Last Post: 19th Feb 2012, 07:22 -
m2ts to m2v
By pcb in forum Video ConversionReplies: 6Last Post: 20th May 2010, 22:22 -
Convert to M2P
By BuzzStPoint in forum Video ConversionReplies: 4Last Post: 25th Dec 2009, 14:24 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 21:25 -
muxing m2v with m2v?
By just in forum Newbie / General discussionsReplies: 4Last Post: 30th Dec 2008, 01:05
