I am getting a "Error 418: Unsupported Video Format" error in VDub using my Leadtek TV2000 XP Deluxe when trying to capture at 640X480.
I have tried turning Preview on and even turned off Overlay. This did not solve the problem. Also tried installing the Bt8xx drivers. Not sure if I'm installing it correctly but all I get is a "Microsoft Visual C++ Runtime Error".
I really want to capture at 640X480. Can this be done?
Yes it can be done but VDub is a P.O.S at capturing video so you're better off using like AVI_IO or iuVCR or another program cause when i use VDub to capture i get nothing but errors, dropped frames and one big ass headache but now i use AVI_IO and havent had one frame drop or trouble with it i love it and i have even captured 3 hrs with no frame loss and i cant even go 30secs in VDub without a error or frame dropping.
[ = Check out my band @ www.samadhirock.com = ] -
i used to get the same error when trying to capture in dub using anything but the default settings.
I was trying to capture at 480x576.
what fixed it was opening my capture program that came bundled with the capture hardware.
I then close the app and open Vdub.
When I do this it works fine.
Vdub must somehow piggyback my primary capture software's settings. -
i-on-s, can I capture at a fixed video frame rate with those programs? I am using VDub to cut/join the files that were captured using the software that came with my capture card and it always complains about un-matching video frame rates.
scottb721, I will try that too. -
VDUB uses VFW (old) drivers, whereas nearly everyhting else uses WDM (new) drivers. You need the WDM wrapper for VDUB to get it to capture anything better than VCD resolution.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I am having the same problem with VDub (I cannot even get a picture).Originally Posted by i-on-s
Where can I get the AVI_IO or iuVCR software? I have the Xcapture card and am just about to give up on it and get something else. -
You can find both AVI_IO and iuVCR in the "Tools" section of this page. They are both demoware and not free
Vdub is not a pile of shit at capturing, I use it effortlessly and would recommend it highly.Originally Posted by i-on-s
Be thankful there are people out there willing to donate this free software, rather than charging for it.
Will Haytgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
virtualdub capturing
By cesar110 in forum Capturing and VCRReplies: 1Last Post: 7th Aug 2011, 00:17 -
Capturing DV - Editing with Virtualdub
By LSchafroth in forum Capturing and VCRReplies: 5Last Post: 27th Nov 2009, 21:19 -
Bitrates, capturing with VirtualDub
By epicap in forum Capturing and VCRReplies: 4Last Post: 3rd Sep 2009, 11:49 -
Capturing using Virtualdub with Vista
By qwerty99 in forum Capturing and VCRReplies: 17Last Post: 27th Feb 2009, 21:59 -
Virtualdub capturing resolution problem
By bloodshed in forum Newbie / General discussionsReplies: 3Last Post: 15th Jan 2008, 13:07
