I am just wondering whether you can actually leave menu out with IC7. I can't seem to figure it out as yet.
Thanks.
so you just want movie only?
there is way if you are interested -
Use DVD Toolbox (freeware) to re-author a movie only, this correctly updates all navigation (which InstantCopy does not) - does not take long.
Then just feed the new authored files into InstantCopy for the transcode.
Simple and high quailty.
DVD Toolbox guide here : http://www.mrbass.org/dvdtoolbox/
Neil -
Mr Zippy that guide is excellent. I have done the same thing using Ifo Edit. The problem is if you still can't get the movie over 4.37gb! You still have to use either IC7, DVD2One or some other app.
Re-authoring does not help then, does it?
Thanks. -
no....you can still let dvdtoolbox do the stripping of audio and main movie only and say it goes to 6GB. Just don't click 'split dvd'. You'll have the main movie only then feed that to Instant Copy.
Pinnacle is leaving gaps, that i cant fill..........
By jorisss in forum Newbie / General discussionsReplies: 0Last Post: 9th Dec 2010, 13:28 -
bfg tech leaving graphics card business
By deadrats in forum ComputerReplies: 6Last Post: 23rd May 2010, 12:51 -
Can you damage an LCD monitor by leaving it on?
By johnsees in forum ComputerReplies: 21Last Post: 27th Nov 2008, 10:44 -
HP5160 printer leaving streaks
By monarc_2000 in forum MediaReplies: 3Last Post: 8th Jun 2008, 07:11 -
adding subtitles and leaving dd 5.1 audio?
By kaoticone in forum ffmpegX general discussionReplies: 3Last Post: 21st Apr 2008, 13:59
