I just got this A04 a few weeks ago and have been burning DVDs beautifully... but it won't burn bin/cue files with CDR. WHY?
I upgraded to 1.40 firmware and then downgraded to 1.31 with no luck still.
I have no clue!
CDRwin will not work, Fireburner will not work, and Nero will not work, they all fail at the start when I try to burn bin/cue files.
My 32X CDRW works fine though but I want this DVD-R to replace it!
Closed Thread
Results 1 to 17 of 17
I hear you.
My answer was meant to be helpful.
Return it and replace it if you can, but still keep in mind that you are better off using your CDRW for CD burns. How can you not have room for it? You likely have two IDE connections on your motherboard, each can have two devices. So even if you have two harddrives you would still have room for a DVDRW and a CDRW.
*shrug* whatever, if you are happy shortening the life of your DVDR drive thats your business.
Mordant, not everyone has room for an extra drive... I'd need to go buy another power splitter (bringing the total to 3 in my PC) to be able to put my CDR back in... I do have one available IDE channel left at least that can use CDR's... Of course I have two DVD+RW's a DVD-ROM and 5 hard drives in my machine...
But Mordant, the guy was pretty rude to you anyway, your answer WAS helpful, just because he didn't state his question and situation clearly you are at fault obviously
Makes you think that maybe we need to learn to read minds better huh?
We will either find a way or make one - Hannibal
Cyrl, 5 Hard Drives?! And 2 DVDRWs?! Whoa...okay, you actually qualify as someone who has no more room =)
Curious as to why you need/have 2 DVDRWs...I've got a DVD Rom for ripping, A CDRW, and a DVDRW.
ElQueso, I've got the Pioneer A04 as well. I think I recall that when I first installed it I tried CDr burning just to see how it went and there were certain types of images it wouldn't burn, I never intended to use it for that so didn't give it much thought. What are you trying to burn? Have you tried both Disc At Once and Track At Once?
Pioneer DVR-560HX-(K or S, it doesn't matter) vs. Macrovison
By blagus in forum DVD & Blu-ray PlayersReplies: 4Last Post: 17th Jul 2009, 11:46 -
I can Burn CDRs but not DVD on my DVD burner
By Hagen89 in forum Newbie / General discussionsReplies: 4Last Post: 10th Dec 2008, 16:47 -
Pioneer DVR-530 disc tray doesn't open
By Alex_x in forum DVD & Blu-ray RecordersReplies: 3Last Post: 22nd Sep 2008, 17:39 -
Pioneer 633h-s Doesn't Boot
By BC-USA in forum DVD & Blu-ray RecordersReplies: 14Last Post: 13th Mar 2008, 13:15 -
My burner used to burn fast enough...but now it doesn't
By Auto Ford in forum DVD & Blu-ray WritersReplies: 7Last Post: 6th Nov 2007, 18:10
His hate is too much for me just watch and be silent. If you need help create new post.
