I decided to finnaly sit down and try my new (first) dvd burner (toshiba R5002). I thought i'd "prcatice" with a dvd-rw first. I checked to insure that my dvd player can read the dvd-rw format before i proceeded (which it can). So I followed a guide from this site https://www.videohelp.com/forum/userguides/141024.php#dvd9dvd2one
The only thing i was unsure about (due to me being a newbie) was if and how do i format a dvd-rw disc prior to writing. I figured i'd just try writing it without formatting and see what happens. Well dvdtocopy spit my disc out giving me an error (i cant remember the exact error). Then i had a disc that a a very smal "line" writen to it and was very unstable to my OS. I found the setting "Erase RW when needed, without warning". I checked it, fed the disc back in and it started to erase it (to my relief). After that i wrote the 30min trial portion of a movie that i had. I thought al was well since windows media player 9 played the movie flawlessly. So i figured any question of having "cheap" or bad media was answered. I stuck the disc in my stand alone dvd player (JVC XV-S300BK) and got an error message.
Is it still possible that my media is incompatible with my burner? Did my initial neglect to format be a problem? Any help/advice is appreciated. Thanks
HoTRoD
You May need to "Finalize" the disc. Without it finalized to drive that wrote it can reaad it, but no other drive will.
SeanWe all like Sheep have gone astray... -
Also check the DVD Players section of this site to make sure your standalone DVD will play DVD-RW some don't or in my Sharp 740U's case will on only some disks.
DVD-Lab Pro Subtitles Encoding troubles
By laste in forum Authoring (DVD)Replies: 1Last Post: 16th Jan 2011, 15:12 -
WMV to DVD+R DL troubles :(
By mastarifla in forum Newbie / General discussionsReplies: 2Last Post: 8th Dec 2008, 18:45 -
Troubles burning OTA HD to DVD
By mattman1968 in forum DVB / IPTVReplies: 3Last Post: 3rd Jun 2008, 08:41 -
.AVI to DVD (troubles with 2 stream audios!)
By whatever911 in forum Video ConversionReplies: 7Last Post: 18th Jan 2008, 19:06 -
DVD Lab Pro Menu Troubles
By Freestyler223 in forum Authoring (DVD)Replies: 5Last Post: 22nd Dec 2007, 00:30
