Is there any other programs i can use to convert d2v to mpeg other than TMPGEnc please i need help TMPGEnc takes toooooo long
First of all, it wouldn't make a SIGNIFICANT difference if you used another encoder than TMPGEnc. You can shorten the encoding by minimizing the quality....
Quality = Time, Less Quality = Less Time.
Otherwise, if you're so destined to find another working encoder, you just need to find another encoder that support VFAPI (which is probably doubtful)...
I say if you're so unsatisified with the encoding time, degrade the quality of the encode (then you're just be unsatisified with the quality in the end).
It's your choice.
<font size=-1>[ This Message was edited by: Jeomite on 2001-09-14 01:19:48 ]</font> -
You can use CCE, CCE is much faster than TMPGenc, but the real problem is your system
No insult, it's just that encoding MPEGs takes a lot of time.
I had a K6-2 500 and it took me 18hrs to encode a 90min movie to MPEG1 (wasn't even using the best settings back then). Now I have a Tbird 1.2Ghz and w/ CCE encoding MPEG2 at 1~1.25x the source runtime (but then I often use 1-3pass VBR). MPEG2 encoding in TMPGenc runs about ~3x the source runtime.
What does this .d2v parse tell me?
By fatcharlie in forum Newbie / General discussionsReplies: 54Last Post: 10th Mar 2011, 18:13 -
converting MPEG-TS to MPEG-PS (from a Noontec V9)
By ninereeds in forum Video ConversionReplies: 2Last Post: 28th Jul 2010, 11:17 -
Syncing audio with d2v
By Norio in forum Video ConversionReplies: 8Last Post: 23rd May 2010, 02:07 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 21:51 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 16:04
