The subject pretty much says it all. I am backing up a dvd which contains the fullscreen and widescreen versions. I don't want the widescreen, so I only kept the fullscreen, and then I ripped the unnecessary audio streams and subtitles. This left me with plenty of space left on one blank DVD-R.
With minimal quality reduction (in Instant Copy.. which is what I used to take out the widescreen and audio streams of Disc 1) I can also fit Disc 2 (bonus features etc..) onto the same DVD-R as Disc 1.
My question is, how can I go about getting both discs to 1, keeping the menus for both. I can use Sonic ReelDVD to create an autoplay menu, which would allow you to choose between the two 'discs' (which would now be on the same DVD-R).... but does that mean I'd have to completely re-author the dvd, and recontruct the menu buttons on the existing menus to point to the correct video streams?
I guess I'm just wondeing if there is any easy way to do this. Ideally I'd like to be able to have 2 VIDEO_TS folders, but i'm pretty sure that's not possible. Thanks for all the help!
Vanda -
I don't think it's a confusing question, I just don't think there's a good way to do it, so that's why no one has replied.
The question has been asked before, but I've never seen a better answer than "rip and re-author the files"....
keep your chin up...
- housepig
How to convert PAL to NTSC keeping the menus?
By user2008 in forum Authoring (DVD)Replies: 8Last Post: 2nd Mar 2009, 10:02 -
How to put 2 DVD onto one, keeping menus?
By LCE in forum Authoring (DVD)Replies: 1Last Post: 11th Jan 2008, 01:37 -
ripping dvds and keeping menus
By eusthebest in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jan 2008, 21:02 -
keeping the menus, removing the extras
By Belfour in forum Authoring (DVD)Replies: 5Last Post: 23rd Jul 2007, 09:27 -
creating .ifo from .vob files and keeping menus
By vishalpatel1 in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2007, 07:40
