I am recording from a set top dvd recorder, ripping the vobs (with smart ripper), pulling wav's out of the vobs (with virtual dub), and then using tmpgenc to combine the vob and wav into an mpg which I will use to author a dvd using dvd workshop. My problem is that the first vob/wav sync and encode great, but for the rest of the mpegs, the audio is out of sync. Can someone tell me how to adjust my current process, or use a new process to create the mpg in sync? Thanks!
In the tools sections there is a program called Eazy VCD this can do the entire process for you or you can open your vob's up in it and the program will take it from there.
I don't think vtilist wants to make vcd or svcd.
You can instead use smartripper and rip/split directly to mpv and wav, that you should be able to use in dvd workshop. -
I would go for Eazy VCD, DVDX made my head hurt and I never managed to get it to work, but maybe that is just me, you may have better luck.
Noob Hi 8
By marcopolos in forum Capturing and VCRReplies: 13Last Post: 4th Feb 2012, 14:47 -
Ripping DVD or Converting VOB files at a specific Bitrate - Help a NOOB.
By Corellian Corvette in forum Video ConversionReplies: 3Last Post: 17th Nov 2010, 20:09 -
Noob question about converting ripped files to AVI
By gingerman74 in forum Video ConversionReplies: 4Last Post: 20th Mar 2010, 23:39 -
Noob question: Converting FLV to Mov --> 0 Kb file
By jmknapp53 in forum ffmpegX general discussionReplies: 5Last Post: 30th Nov 2008, 03:54 -
Help, I am a noob... What program for what I need?
By agent8 in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2007, 19:44
