ok the reason there are sync probs when a file is converted is because the source has some bad frames.
there are easy ways to get around this:
1) get virtual dub
2) open virtual dub, click video, then click scan video stream for errors.
3)when done it will tell you what it found. Then click video, then hit direct stream copy and voila done (thnx again to ZippyP. for the correction)
4)click file, then click save avi let it finish .
5) check to see if the new divx file is in perfect sync (audio + Video)
Then open TMPGEnc
and follow the great guide on this site on how to convert to vcd or svcd.
*****juss a couple notes in some cases you might have to extract the audio from the source, again follow the guide on this website.
*****i take no responsiblity how many encodes or cds you screw up while encodeing.
To the owner/mods if you wanna put this guide on your site juss e-mail me first and ill give you the go ahead, ok
although i dont think its that good just in case, better safe than sorri!
Results 1 to 12 of 12
Audio and video should be set to Direct Stream Copy. Why recompress?
"Art is making something out of nothing and selling it." - Frank Zappa -
I'm referring to Step 3 where you say to click on Mpeg 4 compression. It's better to use Direct Stream Copy (for audio and video) instead of selecting some type of compression. If you use direct stream copy then the file will be saved without the bad frames and with the original compression intact. If you select a new compression there will be quality loss due to the recompression, it will take longer and it's unnecessary. You're stearing people wrong by telling them to select some type of compression and you should probably edit your guide.
What's the point in scanning for bad frames? You didn't delete them. If I follow your guide I find out if there are bad frames, but I don't do anything with them.
OMG, ZippyP. u r a 100% rite my bad
and as for Laddydaddy, i dont know what vdub does wit the bad frames but juss folow my guide.
UPDATeD GUIDE (thnx to ZippyP.)
1) get virtual dub
5) check to see if the new divx file is in perfect sync (audio + Video) -
I think you need to rethink and edit your guide, theres a couple of things pointed out already that arent quite right.
I know you said you wont take responsability, but you dont want some newbie following this guide and getting everything screwed up now do you.. ? -
no i dont want that to happen, but if any1 has any suggestions on how i should edit/re-think my guide, feel free to post ur suggestion and chances are i will change it, i am a very reasonable guy. If u think it sux say so, i wanna kno wat the average/senior user has to say.
*AND AGAIN I TAKE NO RESPOSIBLITY FOR SCREWUPS!!*
thnx, Morco -
Originally Posted by Laddydaddy
8)
You can go back and edit your first post to correct it!
8)
(avstodvd) Converting m2ts to dvd...sudden sync probs.
By newbtube in forum Video ConversionReplies: 17Last Post: 2nd Apr 2011, 23:27 -
Does anyone have an idiots guide to converting telecined dvd's please!
By Emanef in forum DVD RippingReplies: 40Last Post: 18th Jan 2009, 22:04 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
MediaCodeSpeedEdit Guide For Idiots(Me) LG - H58N
By hech54 in forum DVD & Blu-ray WritersReplies: 0Last Post: 24th Aug 2008, 06:22 -
converting from mpeg1 to divx
By mlkwestcoast in forum Video ConversionReplies: 3Last Post: 21st Dec 2007, 11:09
