can u use adobe 6.5 to encode avi to dvd if so how do u do it plz
Hi,
All you have to do is "Export Timeline to MPEG Encoder" in the File Menu.
Regards,Jose Febus -
on the install cd there is a complete guide on how to do this in the extra's folder
how is the quality/speed of Premier's mpeg encoder compared to TMPGEnc?
there is a must have update for the encoder (which is the Main Concept encoder) on the adobe web site ..
it is much faster than tmpgenc - quality about the same .. depends on settings and content. it is very good encoder though . same one in vegas 4.0b -
BJ_M You say there is a must have update for the encoder (which is the Main Concept encoder) on the adobe web site, but when I tried looking for it Icould not find it. Is it possible for yo to post a link for it please
chopper20
http://www.mainconcept.com/adobempeg/downloads.html
I check the Adobe site for updates religiously...and this is the first I had heard of a Main Concept update, too. I couldn't find the above page at adobe.com -- I found a link at mainconcept.com instead.
There's a 1.2 and a 1.3(beta) up right now...I'm about to download v1.2 before I go to work...
Thanks for the heads up, BJ_M! -
Karate Media
Thanks for the link. I have just downloaded 1.3 beta but it appears to have a problem. Will go back and download 1.2
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Adobe Encore
By mobie29 in forum Authoring (Blu-ray)Replies: 33Last Post: 6th Jan 2011, 02:09 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17 -
adobe help!
By alintatoc in forum Off topicReplies: 4Last Post: 14th Apr 2008, 05:45 -
The Shame of Adobe
By Cootah in forum SubtitleReplies: 0Last Post: 16th Jun 2007, 02:32
