During a simulation, I see a log message from VCDEasy stating, "generated image (361874 sectors [80:24.74]) may not fit on 74min CDRs (333000 sectors)"
I suspected my resultant BIN file was going to exceed my 80 minute disc's capacity.
Is there a way to tel VCDEasy to assume 80 minute CD's?
In which case, the same message would only be generated if an image were to exceed the capacity of an 80 minute CD.
i havent found a way to change that either, how ever you would need to tell the encodeing program to keep your size under the 80 min required.
you can overburn with nero if you check it , however some burners wont do it anyways and some dvdplayer wont play them. i have overburned up to 818 and had no problem ,i wouldnt do it every time though. i have just ajusted my encodeing size to allow for the menus i am going to add when i create the bin/cue.
you can go to 79m 59s 71f without overburning on an 80min cd
AutoMKV hangs with message "first normalizing volume - WAIT" message :(
By Jackie78 in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 06:33 -
Can not log onto PC
By Noahtuck in forum ComputerReplies: 19Last Post: 12th Dec 2009, 22:35 -
Log in?
By alintatoc in forum ComputerReplies: 10Last Post: 5th May 2009, 02:04 -
Log Me In
By Lucifers_Ghost in forum ComputerReplies: 3Last Post: 6th Jun 2008, 08:02 -
Log in
By MintyJ in forum ffmpegX general discussionReplies: 3Last Post: 15th Mar 2008, 18:18
