I have just copied two videos using winfast , the end result is perfect . However I need to delete some parts of one video then add it to the other. I used Tmpgenc went into merge & cut and put in both files,cut out what was not needed and then pressed run. The result was perfect joining but with the sound totally out of sync. Can anyone help giving me basic instructions without a lot of technical data.
Mate, on some SVCD/DIVX -> MPG2 using TMPEnc I've had exactly the same problem. The source is fine, the output is bollocks. I have tried everything I can think of, hopefully someone can help.
Here's one bizare problem I had. I had 2 SVCD MPGs. Both in perfect sync. Passed each file into TMPEnc to get a MPG2 compliant file that Ulead says is ok. then use the join tool in TMPENC, still OK. pass fail.
I think, but cannot be sure how to check this, that MPGs need to be cut on an I frame so I think my original files weren't ciut on an I frame and this is causing problems. I have no idea how to check this.
Still if you have any joy, please post your answer.
Audio out of sync after editing in MPEG Streamclip
By Rhymester in forum EditingReplies: 0Last Post: 7th Nov 2011, 06:03 -
Audio sync while editing in Pinnacle
By p_uriel in forum EditingReplies: 5Last Post: 13th Jan 2011, 15:13 -
Sound track editing
By grandsire02 in forum Newbie / General discussionsReplies: 1Last Post: 17th Sep 2009, 19:29 -
Avidemux editing causing audio sync issue
By perdomot in forum EditingReplies: 0Last Post: 14th Sep 2009, 16:29 -
Audio/Video Out of Sync/Lag When Editing Clips
By DrawnIntoIt88 in forum EditingReplies: 2Last Post: 15th Dec 2007, 09:03
