How often should you have your DVD Recorder cleaned and aligned? I have the Panasonic DMR-E30 and the extended warrenty from Best Buy so it is covered?
"How often should you have your DVD Recorder cleaned and aligned? I have the Panasonic DMR-E30 and the extended warrenty from Best Buy so it is covered?"
Well, a VCR you might have to. However, a DVD Recorder is not the same. If it's not broke (yet), don't bother with it. It's good that you do have the warranty though.
Are there any special maintenance issues for a hdd for media players (wdtv)
By yoda313 in forum Media Center PC / MediaCentersReplies: 16Last Post: 25th Apr 2012, 15:27 -
Sony SVO-5800 - Accessing Maintenance Menu
By svenyonson in forum MediaReplies: 1Last Post: 13th Dec 2009, 17:10 -
XBOX 360 Maintenance
By Hsr94 in forum Media Center PC / MediaCentersReplies: 1Last Post: 13th May 2008, 14:55 -
Maintenance ?
By guns1inger in forum FeedbackReplies: 3Last Post: 8th Mar 2008, 05:21 -
Which brand/model wins the prize for ease of HDD maintenance?
By Bud5 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 29th Nov 2007, 01:18
