  1. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    for those wanting 1:1 but it won't fit unless you use a lower level for main title but then it's only gonna be 4Gb and the next highest level is over 4.37Gb then just run the main title at the next highest anyway to get a result over 4.37Gb
    then run the 1st runs files through again but this time keep the stuff you really want at No Compression and reduce the naff stuff to Level 1 to get it down to 4.37GB
    dunno how this turns out but it should do it, dunno bowt quality either but it's gonna be on the naff menu/extras stuff anyway so a Level 1 setting aint gonna do that much damage to an already naff Level 4 setting anyway
    Let's just call it Level 5 for now
    p.s. or do a Level 2 reduction, then a Level 3 reduction resultng in a Level 5 which may be slightly better than a Level 4 & 1
    shoot me down if it's crap but I can't think off anything else for now, unless you run it through DVD95Copy instead
  2. It seems like a very good idea. Basically it is like doing it twice, which is still faster than any other program. It took 33 min in my P3 933 to compress the Red Dragon movie. It will take about 1hr to do it twice. I got to try this one. This is fascinating!
  3. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    it should be a lot faster the 2nd time as it will copy the majority of the stuff across at full speed without processing it
  4. I'll try it tonight.
