Hi, I have a dvd movie, and its burnd on a princo DVD-R.
When I put it in my standalone dvd ( DAEWOO DV-115 ) it won't play. But it see it is a dvd. I'll pressed all the buttons on my remote controll but nothing works.
And in a Sony it plays fine.
The movie was made with DVD2ONE, I do't know witch programm its burnd.
From someone els, i got a new dvd-r movie witch it made by DVDXCOPY
And burnd with It. It plays fine on my DAEWOO player. It was the same brand disk ( Princo DVD-R).
How is this possible ???
Is the problem by DVD2ONE or
Is it a problem witch programm you use to burn DVD-r
And witch burning tool is the best to burn DVD-r that are compatible with
my DAEWOO DV-115 standalone player??
I hope you can help me
PS: sorry for my english.. Its not so good![]()
It's probably the proggie used to burn. You'll find posts where someone has a disc burned with say Nero, and it won't play soi they reburn from the same image on the same brand media with say Recordnow Max, and it works. I would guess thats most likely the prob as other DVD-R's play on that machine, but I can't be sure I pitched my crystal ball when I got saved lol
SeanWe all like Sheep have gone astray...
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
problems playing dvd movies
By bexiga in forum DVD RippingReplies: 2Last Post: 5th Jan 2009, 20:37 -
Problems when playing DVD VOB files
By rbrown871 in forum Software PlayingReplies: 2Last Post: 25th Nov 2008, 21:10 -
MPEG playing problems
By Dave Knowles in forum Software PlayingReplies: 5Last Post: 14th Oct 2007, 08:31 -
Problems with recorded TV playing
By amir77a in forum Media Center PC / MediaCentersReplies: 4Last Post: 15th Jun 2007, 08:57
