Hi. I used to use Win Me for my Video encoding and recently bought a new P4 system with Win 2K pro. I installed TMPGEnc Plus, Divx Pro 5.02 and the Nimo Codec Pack Audio Codecs. I was bale to sucessfuly encode DIVX into VCD/SVCD, however, when I came to rencode a VCD mpeg-1 file, I got a message saying "Cannot open or this media type not supported". This was a standard mpeg-1 file with a *.mpg extenstion and yet it did not work. I installed the latest Windows Media Player (for video codecs) and installed, uninstalled and reinstalled Nimo with no sucess. Anyone know how they can help? Would be greatly appreciated!!![]()
Are you absolutley SURE that it is a
standard mpeg-1 file -
I'm 100% sure because I ripped it off of a PAL VCD myself and I did the check. It also plays perfectly fine in Windows Media Player.
This may not actually be answering your question, but why re-encode a VCD? You can't make it any better, you don't need to re-encode to burn it to DVD so why bother in the 1st place?
Just curious really! -
I see what you're saying, but first, a few things. For example it's PAL and I want to convert it to NTSC. Also, if you encode 2-pass vbr with some filters, you get smoother picture and smaller file size. The point is however i cannot encode mpeg, which is a problem to me.
Ok, I now understand why you want to re-encode. I Can't understand why Tmpgenc won't open an mpeg-1 so a couple of things you can try. 1st I would suggest raising the priority of the directshow filter under environmental settings, this often fixes a lot of 'could not open' type problems in tmpgenc. If this doesn't work, you could always frameserve it from virtualdub.
Windows 2000 Questions
By dafoe in forum ComputerReplies: 2Last Post: 21st Dec 2007, 16:31 -
Core2 Quad with Windows 2000?
By SatStorm in forum ComputerReplies: 18Last Post: 21st Aug 2007, 18:29 -
Windows 2000 Hotfix
By MarioB in forum ComputerReplies: 13Last Post: 18th Jun 2007, 13:39 -
Windows 2000 options, if any.
By AlecWest in forum Capturing and VCRReplies: 6Last Post: 18th Jun 2007, 00:22 -
Windows 2000 question.
By AlecWest in forum ComputerReplies: 34Last Post: 1st Jun 2007, 17:54
