  1. This is the first time I have used the Instantcopy. I followed all the instructions and kept the size below green. When it came to burning, it said your size is too big, you want
    1. Ignore and continue
    2.....
    3.....
    4...
    The size should not be bigger than one DVD becuase actual movie lenght is below the one DVD-R size limit (I checked on the DVDToolbox). I just wanted to test this app.
    What the hell do I do here? Have I done something wrong? Other problem is that neither PDI to ISO or PDI2ISO would work to convert into the .ISO file so I could see what IC has done.
    Thanks.
  2. Sorry I cannot really help as I have only used it twice now and at 4 hours each time I am not too happy as they keep coming out 500Mb too small wasting a lot of space.
    Did you do all of the extras too? I have read that size with this app depends on whether it is 4:3 or 2.35:1 or whatever and also on the hiden settings and reg hacks. Confusing very much...
    Basically with IC 7 it seems very much pot luck to me.
    Try here : http://www.deano.dsl.pipex.com/backup/index.htm
  3. No, I did not do any extras, movie only. I can not even copy the movie only which is below the size limit, then it has some problems. Use DVD2One instead gets the job done everytime.
    Unless someone helps me here!
  4. where are all the experts on this? There have to be answers to my questions.
    Heeeeeeelp!
  5. Is this right that you can not leave out Menu with IC?
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Please wait a few days before you bump your post.
  7. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    Heeeeeeelp!
    one of the expert's who wrote the guides in that link that MaX_NormaL kindly posted, is wondering why you ain't read the info cos it's in bright red
    NOTE: InstantCopy issues & hints explained HERE
    browse through all the links for IC, even the settings one on the main page
