I was wondering..I use TMPGEnc to make svcd's.
is there an option or something I can check off so during fast motion and action sequences the screen does not get blocky and grainy??
thanks for any help you can give!
Click on settings, under Motion Search set it to high/slow (most agree that highest/slowest takes more time but has no notiable quaility improvement).
The the bitrate to the max you DVD player will support (should be able to handle up to 2800kbit/s total). If you're using a lower bitrate then encode with 2pass VBR.
If you choose, click on GOP and enable soften block noise with a setting of 32~40 or so.
How to do they Create Motion in this example
By Thread7 in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2012, 15:17 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 20:11 -
Motion
By augiecrazy8 in forum MacReplies: 1Last Post: 12th May 2008, 00:18 -
motion blur on tv
By ineedhelp007 in forum Newbie / General discussionsReplies: 3Last Post: 18th Dec 2007, 10:49 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
