Hi,
I have some MPEG files I'd like to convert to SVCD. Some are MPEG-1 and others are MPEG-2 files. If I try to create an SVCD with Nero, it takes a while to analyze each file and sometimes brings up an error saying it's the wrong format and would I like to convert it etc.
I'm just wondering if there's a real fast way of determining if an MPEG video clip is MPEG-1 or MPEG-2 format? With AVI files, I can right-click on them (in WinXP Pro) and bring up the properties to see the resolution, codec etc. but I tried the same thing with MPEG files and it doesn't tell me what format they are, what resolution etc.
Thanks!
Green Ghost
Down load avicodec program. http://avicodec.duby.info/. It gives video and audio source codes
The LSX mpeg player has a great mpeg info function.
/Mats -
Thanks - I just downloaded Avicodec and it's exactly the kind of program I was looking for
mysticgohan17,
Could you clarify that? I'm familiar with the TMPGEnc tools, but how do use them to give you info on bitrates and resolutions?
Video duration discrepancy in 'properties'.
By LT2012 in forum Video ConversionReplies: 6Last Post: 20th Apr 2012, 20:06 -
Video Properties
By shockgolf in forum Newbie / General discussionsReplies: 8Last Post: 4th Feb 2011, 23:59 -
AVI video properties missing
By Ayeohn in forum DVD RippingReplies: 3Last Post: 19th Dec 2009, 03:58 -
how to do effectively obtain real time Video multiplexing
By vannigiova in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2007, 11:05 -
MPEG properties
By tonyaldr in forum Newbie / General discussionsReplies: 1Last Post: 12th Aug 2007, 22:42
