I had a reasonable hunt but couldn't find this answered in any of the forums (if it has been please direct me there)
I would like to trim the beginnings and ends off some mpeg1 music video clips that i have so they look a bit tidier when i compile them on a vcd.
I would like to do this without losing any quality is this possible and if so how do i do this? I have after effects, premiere, virtual dub & tmpeg at my disposal or is there something else out there that would do it for me without too much heartache (and preferably freeware)
thanks in advance for any advice and sorry if this sounds like a dumb question i couldn't find anything newhere on the subject.
TMPGenc can do this just fine.....
Open TMPGenc and cancel the wizard if it starts. Select file/mpeg tools then hit the merge and cut tab. Set "type" to mpeg1 then click "add" button and browse to your video file. Highlite your movie and hit the "edit" button...move the slider to where you want movie to start and then click the { button. Then move the slider to where you want it to end and click the } button and then click OK. Now click "run" and it will clip the movie for you.
Video Degrading fast
By dwcjr69 in forum Newbie / General discussionsReplies: 5Last Post: 30th Dec 2011, 03:43 -
Video Quality Degrading
By Buu in forum Newbie / General discussionsReplies: 46Last Post: 1st Feb 2011, 11:58 -
MPEG1 Editing Program?
By MindF in forum EditingReplies: 3Last Post: 2nd Apr 2008, 13:28 -
Video Degrading!
By mai_hnf in forum SubtitleReplies: 3Last Post: 27th Sep 2007, 20:39 -
Converting without degrading
By nationofsize in forum Video ConversionReplies: 1Last Post: 20th Aug 2007, 16:09
