I'm in the process of converting several of my old VHS tapes to DVD, and am wonderiNG what the best method/encoder is. As i've already painfully learned, capturing to the bloated DV format, then re-encoding easily gets the best results. However, im wondering if it matters which DV capture app i use? So far i've used VideoStudio 7 and M$ Movie Maker to capture.
Also, i've been using TMPCENC to re-encode the DV files to fit onto my DVDs, i'm wondering however, what are the optiminal settings when using TMPCEnc for doing such conversions?
Thanks for the infos.
Results 1 to 1 of 1
vhs tape will NOT move through vhs recorder at all
By tepeco in forum RestorationReplies: 52Last Post: 24th Oct 2022, 13:31 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 10:32 -
VHS tape artifact
By dumham in forum Capturing and VCRReplies: 6Last Post: 23rd Aug 2009, 04:27 -
Archiving VHS Tape
By mts37 in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2007, 02:17
