ok i worked on a dvd for like 3 days figuring out dolby digital and mpeg2 conversion now i finally got 3 1 hour videos on 1 disk using dolby digital audio but in the menu i linked 1 movie 2 times and 1 movie not at all i already deleted all the files cause i have limited disk space i know the other movie is on the disk cause i put it in the dvdrom and found it in one of the vobs now can i rip the vobs into 3 differerent mpeg2 files so i can just link it right or am i gonna have to convert my compressed files all over again?
You should be able to rip it, and the re-author it. You won't have to encode it again as its already the correct size to fit on a dvd-r, Just rip it and use one of those proggies that puts the .vob's back together and demuxes it like DVD2AVI but uses .m2v for the vid instead of d2v
SeanWe all like Sheep have gone astray...
Fix bad avi file
By TBoneit in forum Video ConversionReplies: 8Last Post: 4th Oct 2011, 11:17 -
ADS Pyro A/V Link - Firmware u/g to fix VHS dropped frames
By pbanders in forum Capturing and VCRReplies: 16Last Post: 24th Mar 2011, 22:40 -
The timing between movie and subtitle is bad. can I fix that?
By Codonauta in forum SubtitleReplies: 4Last Post: 28th Dec 2009, 13:39 -
how to fix: MKV to MP4 with bad ac3?
By cjh1452000 in forum Video ConversionReplies: 2Last Post: 28th May 2008, 03:11 -
Can anyone send me a link on how to fix an out of sync problem?
By gomer in forum Newbie / General discussionsReplies: 2Last Post: 10th Nov 2007, 23:47
