I'm trying to figure out why I'm having a problem with audio/video sync when converting through TMPGEnc. I'll strip the audio, convert if if it's AC3 and run it through the TMPEnc converter and burn to VCD with Nero. I've verified framerates through GSpot and they're fine.
The problem is, the end result almost always has audio sync problems, sometimes quite severe. The video has to jump to catch up, or the audio is several seconds behind the video.
Any suggestions to correct this? Thanks.
Results 1 to 1 of 1
Audio out of sync when converting from MKV
By carlmart in forum Video ConversionReplies: 8Last Post: 22nd Dec 2012, 17:07 -
No video and bad audio when converting AVI to DVD (ffmpegX)
By leosmith in forum ffmpegX general discussionReplies: 2Last Post: 29th Mar 2010, 15:06 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Audio is off sync from video after Converting?
By PHNeedsHelp in forum Authoring (DVD)Replies: 1Last Post: 23rd Nov 2009, 18:19 -
Bad audio sync with known good xvid files
By damax452 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 17:22
