  1. Have gotten about 4 disc errors in the last 4 attempts...I was using Nero and followed the usual steps and kept ketting disc errors when trying to play in stand alone DVD player. I was also using IFOedit for the first 3 then tried DVD95Copy but still the same result. I downloaded RecordNow MAX and I am not sure how to use it. Could someone post a guide on how to use RecordNow MAX or fix my problem in NERO. Any help would be appreciated...
  2. Please...some help!
    Aug 2001
    Netherlands
    Hi!
    In recordnow max: select the 'data' option (close the wizard), drag your complete VIDEO_TS and AUDIO_TS folders to the inputfield and burn it.
    Some versions of Nero cause problems with compatibility, so try to avoid this program at all cost, just to be certain.
  4. What about Joilets and UDF and stuff like that?
    Aug 2001
    Netherlands
    close the wizard, choose the DATA option and right-click in the input field, click on Recording Options... here you can configure more.
    I use standard settings and have burned 10 dvd's with it; they all even play fine in my PS2 drive.
  6. What about StandAlone players without DVD+R Compatibilties?
  7. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    If it isn't DVD+R compatibile, then no matter how you burn it, it won't play. because it's not compatible. see?
