Can someone tell me how to fix this error?
Im running it on Win XP Pro
INPUT:
DeCSS-DeMacrovision(marked)Each VOB/CELL
Audio:
Dolby Surround(marked)
EnglishAC3 6ch (0x80)Normal Quality 48Khz Volume 3
Frame Rate:25.0(PAL) Detect Progr. 24Hz
Misc:Audio/Video synchronisation
OUTPUT:
AVI(Divx)
Avi Specific:Lame mp3 3.92MMX 96kb/s 44.1Khz 16bit Q1
Divx Pro 5.0.3 Codec "Enable Video"
Resolution-576x240 Zoom-None Resize-Bilinear MMX Maxframe (Whole)
Volume dont exceed-Infinite
Then when I click encode a error window pops up saying
"Error
AviStreamWrite failed."
Some one plz let me know if you know how to fix this. Thanks
Uncheck "Dolby Surround"and in "iDCT" & "Resize" select the proper settings for your CPU.
Sorry for answering back so late.
Well I tried what you said and still get same error.
My CPU is a AMD Athlon XP 2000
Got any more Ideas?
If possible let me know if you can send me screenies of your dvdx input & output.
Thx for helping me!
BD Rebuilder: ERROR "failed video encode, aborted"
By jlm86 in forum Blu-ray RippingReplies: 1Last Post: 22nd Feb 2011, 19:57 -
What is the problem when it says "failed video encode, aborted "?
By PERSHON in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 13:33 -
Panasonic DMR-ES35V "Self-Check Failed," refuses to run
By MattOKC in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Jul 2010, 18:50 -
ATI AIW 9600XT, "TV failed to initialize the video" problem...
By etecnifibre in forum Capturing and VCRReplies: 11Last Post: 20th May 2008, 16:08 -
failed to connect Output pin 0x0093ae4c ["Stream 00"] on AVI Spli
By carcrashhearts in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 13:46
