? what program can i buy that would alow me to use mpg files that are over 138 minuts long to be reduced to fit on a dvd-r disc?
but adjust for the minimal shrinkage , also can one select the quality of the audio as well
?!? MPEG file size is based of the bitrate and runtime. Use a bitrate calculator (look to the left under tools) to find the bitrates to fir your source runtime on a 4.3GB DVDR disc.
The only way to change to the bitrate is to re-encode the MPEG (audio and/or video). You can do this with several programs: TMPGenc, CCE, MainConcept, etc. See the convert section to the left for more info on each program.
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2008, 23:20 -
I need a good program. Some advice please.
By hellfire45 in forum Video ConversionReplies: 4Last Post: 15th Feb 2008, 10:35 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 22:39 -
I want to change my burning program, advice needed
By jesterhud in forum Authoring (DVD)Replies: 4Last Post: 20th Aug 2007, 13:43
