Can anyone else verify this ?. My burner died (after about 100 burns) so I sent it in. When it went in I could burn Accu media at 2x with firmware 1.0f.
When it got back from the service center they had loaded 2.0e into it and now I can only burn the same media at 1x.
Has anyone gone back from 2.0e to a previous version ?. I still have the 1.0f firmware, is there a place to get other versions and if so can anyone suggest a "preferred" version ?.
Results 1 to 10 of 10
Yes, the new firmware burn accus and leaddata at 1x that why I went back to 1.0g firmware...
Where can I find 1.0g ?. I've only got 1.0f.
Nevermind, I found it here
http://forum.rpc1.org/dl_firmware.php?download_id=302 -
well f should work to. if not i can send you the other if you want because i had the same problem.
Do you have a link to where I could get a RMA to send my Sony DRU500A back for replacement? It died after about 300 burns.
I called Sony Support at 800-588-3847 to get the RMA and then they gave me an address in CA to send the drive in to.
The people at the service center are pretty nice and if you call them and be polite they helped get my drive back quicker. -
NO I've sony DRU500A updated to 2.0e and 50 dvd-r accu with id SONY and all burned to 2X just one pixellization in psx2
bye
mastercut -
The various Sony DRU500A firmwares can also be found here
www.sonydru500a.com
good luck -
Accu Media
With 2.0e it takes 1 hour to burn a 4.7gig dvd-r
with 1.0g it takes 30 min
I'm sticking with 1.0g
Newest sony bdp-s380 firmware contains cinivia
By johns0 in forum DVD & Blu-ray PlayersReplies: 30Last Post: 1st May 2016, 07:31 -
DVD burner only burns DVD-RW now and firmware problem.
By yocahu in forum DVD & Blu-ray WritersReplies: 2Last Post: 14th Mar 2010, 22:23 -
sony DAV-DZ100 Firmware update problem
By kanu in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Nov 2009, 06:15 -
FIRMWARE for SONY DVD
By yangp in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Dec 2008, 15:44 -
FIRMWARE SONY DVP-k82p
By xunter in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Sep 2008, 10:37
